TwinTurbo.NET: Nissan 300ZX forum - Not sure this would yield a big leak but was the
jzack
on September 12, 2012 at 8:09 PM
Rear Main Seal Trouble Shooting
posted by Summeronthechain (MN)
on September 11, 2012 at 09:33 PM
crank shaft scored at all from the old original seal?
21:33:50 09/11/12
I would have put RTV around the seal the 2nd time around! (n/m)
JonnyZ(SoCal)
21:41:46 09/11/12
I use rtv on the full length of those oil pan seals.
Evan_Wright (Ca)
00:27:53 09/12/12
I did exactly this the second time I replaced the seal. (n/m)
09:14:51 09/12/12
Make sure your oil pan bolts are tight.
megaDan
07:18:20 09/12/12
I double checked all oil pan bolts on the rear, all is tight (n/m)
09:21:05 09/12/12
I don't think it's the rear seal. From my experience it...
craigz96tt
07:51:12 09/12/12
Thanks for the tip.
09:22:53 09/12/12
How much oil are you running? (n/m)
Woody75 (Denver)
10:51:55 09/12/12
4 quarts....one of the first things I checked.
13:29:52 09/12/12
Not sure this would yield a big leak but was the -
jzack
20:09:54 09/12/12
I double checked it visually when installing the second seal
21:58:21 09/12/12
